Критерий истины не практика, а собственная душа. /Авессалом Подводный/
Все на метеоры!!!
Kavalaksala
Благодарности: 4
Добавлено: Ср Янв 11, 2012 21:02    Заголовок сообщения: Ответить с цитатой
bis писал(а):
19-20-21-22 января ожидается метеорный поток, открытый финнами в 2010 году...
Дзякуй вялікі! Трэба будзе прагуляцца =)
Добавлено: Чт Янв 12, 2012 01:05    Заголовок сообщения: Ответить с цитатой
СООБЩЕНИЕ из скайпа ...
METEOR OUTBURST OF GAMMA URSAE MINORIDS
P. Jenniskens, SETI Institute; and Esko Lyytinen, Helsinki, Finland,
report that six Finnish observers using wide-angle video cameras (limiting
magnitude +1) observed a possible outburst of gamma Ursae Minorids, a newly
discovered stream (cf. CBET 1938) that until now was only known from radar
observations (limiting magnitude +8) of much weaker meteors. On the night
of 2010 Jan. 20/21 (solar long. = 300.7 deg), Ilkka Yrjola (Kuusankoski,
Finland), Pekka Kokko (Ylikiiminki), Mika Jaervinen (Joutsa), Ari Jokinen
(Jarvenpaa), Timo Kantola (Piksamaki), and Jarmo Moilanen (Vaala) detected
meteors radiating from a radiant at R.A. = 228.0 deg, Decl. = +66.4 deg (10
meteors in total: 4, 1, 1, 1, 3, and 2 meteors per site, respectively). One
three-station meteor on Jan. 20d17h17m55s had a radiant at R.A. = 230.2, Decl.
= +67.1 and speed V_g = 29.6 km/s, corresponding to the following osculating
orbital elements: a = 2.84 AU, q = 0.955 AU, e = 0.664, Peri. = 202.3 deg,
Node = 300.404 deg, and i = 48.5 deg (equinox 2000.0). Within the error,
this radiant is identical to that of the recently discovered (CBET 1938)
gamma Ursae Minorids shower (IAU Meteor Shower No. 404), which peaks at solar
long. = 299.0 deg and is active for 11 days. On the day of the video
observation, the annual shower would have radiated from R.A. = 232.5 deg,
Decl. = +66.2 deg, with V_g = 31.8 km/s, in good agreement with the radiant
of what appears to be a meteor outburst. The observed 2010 meteors are
relatively bright (+0.55 mean magnitude), which implies that the shower had a
low magnitude-distribution index of chi = 1.65 +/- 0.35. This suggests that
the shower had an outburst of relatively bright meteors. The shower was
still weakly active on the night of Jan. 21/22, when Yrjola and Jaervinen
captured a two-station meteor radiating from R.A. = 229.8 deg, Decl. = +66.4
deg, V_g = 29.6 km/s (solar long. = 301.612 deg).
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
superseded by text appearing later in the printed IAU Circulars.
Добавлено: Чт Янв 12, 2012 07:32    Заголовок сообщения: Ответить с цитатой
Надо будет поднять данные радиотелескопа за январь 2010....
Добавлено: Чт Авг 09, 2012 16:21    Заголовок сообщения: Ответить с цитатой
Всем привет !! Smile
Подготовлена одна группа наблюдателей метеорного потока Персеиды..!
Я отправляюсь к своим ученикам в Барановичи - вторая точка наблюдений !
Простейшие наблюдения будут проводиться по двум задачам:
- простейший счёт метеоров;
- зарисовки метеоров на картах и определение радианта.
Основная цель - не столь научные наблюдения - сколь привлечение молодёжи к систематическим простейшим и требующимся в науке наблюдениям.
Не всё ж мне в одиночку почти и в около 50 лет по возрасту --- наблюдать, считать падающие звездочки ...
Пора и смену готовить - хотя бы такую, как в Марьиной Горке в 1998-2007 г.г.
Новости по метеорам можно найти и на
http://www.astronomy.ru/forum/index.php?topic=3128.new;topicseen#new
Добавлено: Чт Авг 09, 2012 16:58    Заголовок сообщения: Ответить с цитатой
Смена это хорошо. Но как долго она продержится?
Добавлено: Чт Авг 09, 2012 19:22    Заголовок сообщения: Ответить с цитатой
Ну, как заинтересуешь, так и продержится. Если ничего не делать, то и ничего не произойдет.
Добавлено: Пт Авг 10, 2012 01:36    Заголовок сообщения: Ответить с цитатой
логично
MarsianskiAlien
Благодарности: 12
Добавлено: Пт Авг 10, 2012 21:59    Заголовок сообщения: Ответить с цитатой
Смена - всегда хорошо в науке, как по мне. Это едва ли не единственный способ эффективно идти в ногу со временем. Жизнь и затрачиваемые усилия - не бесконечны. Ну, это я об идеальном случае, конечно. Без учета теплых насиженных и так внезапно любимых мест )))
Добавлено: Сб Авг 11, 2012 21:10    Заголовок сообщения: Ответить с цитатой
В Барановичах наблюдения Персеид начались ...
Вечером 10 авг. эффектно прошёл просвет с 22.30 до 2 ч ночи 11 авг. Метеоров немного. Отправил отчёты в IMO.
Последний раз редактировалось: bis (Сб Авг 11, 2012 22:39), всего редактировалось 1 раз
Добавлено: Сб Авг 11, 2012 22:38    Заголовок сообщения: Ответить с цитатой
Wink Согласен - редко когда смена так долго держится ...)
Добавлено: Вс Авг 12, 2012 01:10    Заголовок сообщения: Ответить с цитатой
Ну вот ...
Ещё интервал времени пронаблюдали в Барановичах..
Завтра расшифрую диктофон ..)) Небо мутное .. Метеоры Персеид пачками вылетали ... Но немного ..
Добавлено: Вс Авг 12, 2012 14:10    Заголовок сообщения: Ответить с цитатой
В ночь с 11 на 12 августа я заметил 74 персеида. Видел пачку персеид 2 и 3.5. Ярче 0 метеоров не видел. Отчет в ИМО отправил. Параллельно проводил фотопатруль метеоров с фишайником и цифрозеркалкой Никон Д60. Один метеор-персеид попался. Яркость примерно -2. Он пролетел в поле зрения видеокамеры, но записи еще не смотрел.
 Размер файла:  104.23 KB
 Просмотрено:  11464 раз(а)
s@va
Добавлено: Вс Авг 12, 2012 23:58    Заголовок сообщения: Ответить с цитатой
10 минут прогулки перед сном в Польском городе Влоцлавек и я насчитала 24 персеида..около 6ти довольно ярких) впечатлило)
Добавлено: Пн Авг 13, 2012 01:36    Заголовок сообщения: Ответить с цитатой
Ну вот ..
И я сегодня на заслуженном отдыхе ... и все потому , что за пивом не сходил ...!!!
Вот вчера и позавчера - как только зайду за пивом - сразу небо проясняется и наблюдать можно (не до пива становится) ...
А сегодня просто не пошёл - масса учеников пришла ...
Ну и как всегда - облом на самое явление ...
Добавлено: Пн Авг 13, 2012 02:19    Заголовок сообщения: Ответить с цитатой
В Биробиджане зафиксирован метеорный дождь ... Кто-нибудь ЭТО может подтвердить ??
Информация такова -- Персеиды давали за 10 минут около 18-20 метеоров (от 7 до 11 метеоров за 3 минуты => 140-220 метеоров в час) ... Они были слабые по блеску ...
Smile
Добавлено: Пн Авг 13, 2012 04:15    Заголовок сообщения: Ответить с цитатой
Понаблюдал 1 час 10 мин, небо около 3m, город. Итог: 20 Персеид (из них 5 очень ярких), 2 Акварида.
Добавлено: Пн Авг 13, 2012 04:31    Заголовок сообщения: Ответить с цитатой
А я - в Крыму. И как максимум, так и циклон пришел. Посему только под утро всего часок понаблюдал - застал ужк так сказать концовку... Наловил 24 Персеида и 6 остального всего...
Добавлено: Пн Авг 13, 2012 05:23    Заголовок сообщения: Ответить с цитатой
Я отнаблюдал максимум в разрывы облаков. 22 персеида....
// Header section
night 2012-08-12/13
begin 2012-08-12 2029
end 2012-08-12 2322
observer "Ivan" "Sergey" "SERIV"
location 26 44 E, 54 16 N
site "Molodechno" "Belarus" "24101"
// Shower section
shower PER 046 +58
shower SPO
// Number section
// Interval RA Dec Teff F Lm PER SPO
period 2029-2044 000 +54 0.250 1.42 5.20 C 7 C 0
period 2126-2142 330 +40 0.260 2.00 4.70 C 2 C 1
period 2143-2154 230 +60 0.180 2.00 5.20 C 6 C 1
period 2206-2229 000 +54 0.380 1.42 4.80 C 6 C 1
period 2256-2322 000 +54 0.430 1.00 4.00 C 1 C 0
// Magnitude section
// Show Interval -6 -5 -4 -3 -2 -1 +0 +1 +2 +3 +4 +5 +6 +7 Tot
distribution PER 2029-2044 - - - - - - - 2.5 2.5 1.5 0.5 - - - 7.0
distribution PER 2126-2142 - - - - - - - - 1.5 0.5 - - - - 2.0
distribution PER 2143-2154 - - - - - - 1.0 - 2.0 3.0 - - - - 6.0
distribution PER 2206-2229 - - - - - - 2.0 - 2.5 1.5 - - - - 6.0
distribution PER 2256-2322 - - - - - - - 1.0 - - - - - - 1.0
distribution SPO 2126-2142 - - - - - - - - 1.0 - - - - - 1.0
distribution SPO 2143-2154 - - - - - - - 0.5 0.5 - - - - - 1.0
distribution SPO 2206-2229 - - - - - - - - - - 1.0 - - - 1.0
Добавлено: Пн Авг 13, 2012 21:15    Заголовок сообщения: Ответить с цитатой
А вспышки активности Персеид - явно кто-то захотел похвастаться ))
И я аж очумел - неужели мне и моим ученикам - в который раз - ТАК не повезло ??
Добавлено: Пн Авг 13, 2012 21:18    Заголовок сообщения: Ответить с цитатой
Кстати, вспышки активности не видела и вторая моя группа учеников ... Но они пока в одном месте Беларуси - а я в другом ...
Страница 8 из 10
